Alternative LHM hoses
Juliso35
Unread post by Juliso35 »
Hi
Just passing to say hello and show some pictures of the new PVC transparent hoses that I am implementing in my car. Because the parts in my country is just beginning to be scarse sometimes is necessary to try other ways :) :-D
I think it gives a look a little bit cyborg lolol :oops:
I hope these be useful to someone!!!
:D Image :D
Old-Guy
x 32
Re: Alternative LHM hoses
Unread post by Old-Guy »
Return and suction pipes only I hope! :-D :-D
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
They do look good though. Easy to keep an eye on the fluid colour too.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
andmcit
x 30
Unread post by andmcit »
What spec is this Xantia then!? It's a CT Turbo but doesn't show the hydraulic feed
for the clutch on either side of the bulkhead!?
Like the skeleton look on the pipe work - makes it more obvious it's all doing something!
Nothing moves you like a Citroën
Mandrake
x 695
Unread post by Mandrake »
I would be very dubious about running standard clear PVC pipe across the top of the engine for the pump inlet, that type of material will soften greatly with heat from the engine, and being under suction the pipe may collapse, starving the pump of oil. Any hydraulic pipe used under suction must either be very thick walled or have a reinforced wall that is designed not to collapse under suction.
It shouldn't really be too hard to find proper mineral oil resistant hydraulic pipe - its used on tractor hydraulics and just about any machine with hydraulics, that's what I replaced the pipe from the tank to the pump with on my previous Xantia:
There are two different sizes, the attachment at the tank end is larger than the pump end, so I used two different diameter pipes and joined them with a fitting using jubilee hose clamps:
While the PVC pipe might work for a while, its not a suitable long term replacement.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Juliso35
Thank you all for your responses!!.
Mandrake you are right!!: Of course... I've noticed the same thing. They become very soft with the heat. Anyway this is a repair that I have under observation and permanent care. I also tried pipes similar to those in your photos but these were very rigid and replicate the original curves was not so easy.
Thanks again for the comments. I have two months with these hoses installed and so far have not problem. These are clear PVC hoses of a thick-walled reference. They almost have 2 mm !!.
:D Image :D
