Xantia Instrument Panel Removal.
David Goddard
At last I have got round to removing the panel to change several lights.
Procedure:
Steering wheel off (follow air bag removl instructions).
Top and bottom shrouds off.
Black fill-in piece above the fuse box removed (2 screws)
Switch panel off (screws on the right, clips on the left)
Un-plug switches.
Instrument panel is held by 2 screws at the bottom and one at the top.
Panel is fulled forward and the 4 electrical connectors un-plugged.
The trick is to carefully ease out the to plasic clip which will have stuck to the padded cowl. Use a small knife. Otherwise the panel won't budge!
I bought 10 new bulbs - there are at least 20 - may be 25. I though that only 3 of mine had blown. In fact 6 had including the low oil level light - which would never have been illuminated in the cars life!
Procedure:
Un-plug switches.
kafkaian
David Goddard
kafkaian
Thanks for the info David. This contradicts what I was told today at Halfords, Birmingham, Selly Oak branch and they were indeed not on their corresponding list. Perhaps, according to Halford's marketing team, Citroën cars do not exist in Birmingham !!!! Now that would be funny.
GSF N95932 BULB 12V 1,2W 5MM WEDGE DASHBOARD BULB 12V 1.2W CAPLESS (286) 35 pence (41 pence VAT inclusive)
frankielunn
Did my dash lights today changed 8 bulbs didnt realise there were so many back there,bit fidly especially the shrouds also the centre screw retainer in top of dash cowl definately need to prise it out carefully or it won't budge as david's previous post mentioned.... but now all illuminated fair dinkum.got bulbs from europarts 30p each.... HAYNES useless as usual.
davethewheel
frankielunn
yes david i tried doing it with steering wheel on but it wasnt hard to take it off,only prob i had was getting at screws holding airbag on, you have to turn steering wheel thro 180 degrees so you can get at the holes behind but as you have disconnected battery you can't start engine to get the power steering pump going so brut force is needed which goes against the grain as thinking of doing damage trying to turn the wheel with no power if you get my drift anyway thats another job done.many more to do tho i'm afraid.
stoofer
2512Steve
Alternative method instead of taking off air-bag and steering wheel is, after removing top & bottom covers and disconnecting switches, to undo the four nuts that hold the column in place and drop the column. Just make sure that all connections are pushed firmly home, as you will have to dismantle everything again if any of the switches don't work (I've done it twice).
Might seem a bit heavy-handed, but it does give extra room to access all the screws, saves dismantling the steering wheel/air-bag and possible mis-alignment of the steering wheel when putting it back on.
Regards,
Steve
Regards,
Steve
(Current) '96 Xantia 1.9TD Est, 148,000 miles
(Past) '89 Peugeot 205 1.9D Hatch
'90 BX1.9D Est x2
'89 BX1.9D Hatch
B4 going diesel:
Vx Ventora 3.3, Victor 3300 Est, Triumph 2000 Est, Jaguar Mk V11M, Ford’s; Cortina Mk 1 1500 x4, Anglia 997
'90 BX1.9D Est x2
'89 BX1.9D Hatch
B4 going diesel:
- x 1484
"Alternative method instead of taking off air-bag and steering wheel is, after removing top & bottom covers and disconnecting switches, to undo the four nuts that hold the column in place and drop the column."
Isn't the whole point that you have to take the steering wheel off to get the shrouds off, since the upper shroud has to come off first to give access to the screw(s?) that go downwards into the bottom shroud - and the steering column goes through the top shroud?
Unless someone's been there before and cut the top shroud and wrecked the screw
reblack68
The only reason the shrouds have to come off is to gain access to the screws behind them. This can just be done with the top shroud in place (but unscrewed) so it would be quite easy with the column dropped. I considered dropping the column myself but had a go at reaching the screws first and managed quite easily. It all depends how much you like doing fiddly stuff.
Richard
Care of a 1994 205 D.
stoofer
to answer my own question: the bulbs can be replaced easily on the Mk II dash, and its easy to take the whole thing apart if needs be.stoofer wrote:I have a Mk2, Haynes says helpfully that it 'might' be a sealed unit and I 'may not' be able to replace any bulbs - oh so wonderfully useful, thanks Haynes, I'm glad I paid good money for you.
whats the truth?
davek-uk
I've had the shrouds off a couple of times with the column in place but in the lowest position. It's pretty easy, but fiddly, and requires gentle bending of the plastic to get the screwdriver in to get the screws.
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
CDazza76
Clogzz
- x 40
There’s no risk of the airbag deploying for no reason when removing it.
There are quite a few topics here dealing with steering wheel removal, but this is all I could easily find:
http://www.aussiefrogs.com/forum/showth ... p?p=291077
