anti roll bar
mikep
anti roll bar
Unread post by mikep »
My 1996 Xantia has failed it's MOT for the first time. Reason given by Kwikfit is worn nearside anti roll bar.
They also added it is usual to replace both at £63 each plus an additonal £32 for tracking.
Can anyone tell me if this an accurate statement ?
mikep
Citroen Xantia auto sx 1996
Monkeyfeet
(Donor 2022)
Re: anti roll bar
Unread post by Monkeyfeet »
Do they mean the drop links that attach to bar and hub? If so then they're easy to swap but can't see how they'd affect the tracking???
(drop link is a short bar with balljoint at each end)
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
mikep
Re: anti roll bar
I asked the symptoms of a worn anti roll bar, and they said a knocking sound when cornering.
To be fair it has not been handling the bumps and does pitch too much when cornering, so
maybe they are right. I think they also said replacing the ARB's can affect the tracking.
mikep
lurchy666
Re: anti roll bar
Unread post by lurchy666 »
anti roll bar links shouldnt affect the tracking, but if you replace them make sure you get the right ones (there are 2 types, a kinda l shape one and a z shape one) and that you get good quality ones as the cheap ones ( from ebay land) seem to only last a few hundred miles before going again, try gsf for them, also before you do them give the threads of the old ones a good cleaning up with oil or wd before doing them as i couldnt even budge mine and ended up gettin annoyed and using an angle grinder on them, also if you car do them on high suspension so the arb wont move when you get one side off
c5 2.2 auto hdi estate 52 reg
lurchy666
Re: anti roll bar
also on my hdi estate when the anti roll links were in need of repair there was a knocking over bumps but as soon as you turn and put some stress on the arb the knocking stopped,
x 8418
Re: anti roll bar
There are split plastic bushes at each end of the anti-roll bar that sit under the clamps next to the P Bushes. Conceivably these can wear and if they do are easily enough replaced. Certainly their replacement (or drop links) will not require tracking...
I'd get the MOT tester to explain precisely what he was not happy with. He should be able to tell you in exquisite detail and if not then report him to VOSA as incompetent.
That they quoted for tracking suggests they're working up to a fast-one on you.
x 5672
Re: anti roll bar
Kwik-Fit? That could never happen :roll:
mikep
Re: anti roll bar
I will definitely speak to Mot tester tomorrow when I collect and let you know his answer.
mikep
lurchy666
Re: anti roll bar
if you can put your suspension on high turn your wheel and get him to point to the exact bit he wants you to replace
mikep
Re: anti roll bar
Collected the car back today and asked a few questions and was told it failed because ' the offside front ARB linkage ball joint dust cover was excessively damaged so that it no longer prevents the ingress of dirt'
In regard to the tracking, they said whenever work is done on the suspension geometry, the tracking is checked, In my case this should have been checked FOC before attempting to charge me and he apologised for not making this clear.
So Citrojim was right, they were trying a con by trying to get a payment for tracking when it was not even checked to see if it was necessary.
Thanks all for the advice.
mikep
lurchy666
Re: anti roll bar
glad you didnt get conned, i wonder how many other ppl have fell for it,
the arb links are pretty easy to do (as i dont think they do the dust covers seprate) as said before if your good with a set of spanners,
mikep
Re: anti roll bar
Lurchy, would have attempted it a few years ago, but at 76 I'm a bit past it .
mikep
