battery change
oneday
battery change
going to buy a new battery at the weekend the engine was a bit slow cranking in the cold weather this morning so think its time to change it. whats the best one to get ah and so on
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
the_weaver
Re: battery change
For my ZX 1.9D, I bought an Exide Premium battery from:-
http://www.carparts4less.co.uk" onclick="window.open(this.href);return false;
It seemed like a good deal. The cheaper Exide Excell battery is the standard battery they offer, but I went for a slightly better one, as I was having starting problems, and diesels need a good battery.
Carpart4less are a cheaper version of Eurocarparts (same stock, 20% cheaper?) but probably mail order only. They usually do free delivery on batteries.
You could get the same battery from Eurocarparts (but a bit more expensive), and pick it up yourself from the shop. There are sometimes discount codes available for Eurocarparts, that can be found on the internet. Try searching on Google for them.
When buying a battery, compare the Ah rating, and the CCA or "Cold Cranking Amps" rating. That's the amount of amps that the battery can deliver on a cold morning, to start the engine. Diesels need bigger batteries than petrol engines usually.
The Exide battery is sealed. I don't think it can be topped up, and shouldn't need to be. A lot of batteries are like that now. If you want one with access plugs, you might be able to find one if you hunt around.
Paul
Paul
ZX 1.9D, 1993, 218K.
Lighty
- x 34
Re: battery change
SDL, Minofern do Exide, in you neck of the woodsoneday wrote:going to buy a new battery at the weekend the engine was a bit slow cranking in the cold weather this morning so think its time to change it. whats the best one to get ah and so on
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
c.morewood
- x 55
Re: battery change
Before you take the plunge ...just check the positive and negative leads.. make sure they're not getting hot when cranking.. I bought 2 new batteries before I discovered it was the + lead causing the problem and a couple of years later the - ve gave up as well.
Got my Bosh Batteries from Costco Great value for car bits and oil.. I save more than the renewal on my oil purchase each year.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
john
Re: battery change
i have a 25% discount code for eurocarparts should you go that route.
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
oneday
Re: battery change
thanks for all your help and offers bought a bosch one today thanks to everyone
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 1240
Re: battery change
Check the websites, some give the battery weight, generally the more lbs of lead per £ the better the battery.
