CITROEN C5 REAR SHOCKER BOOT
Does anyone know if you can get the boot seperate from the dealer? Or has someone got one lying around which I can buy?
Re: CITROEN C5 REAR SHOCKER BOOT
i presume this is a C5 with hydraulic suspension,
if you send me the last 8 digits of your chassis/VIN No. i will get you price and part No.
Regards, malcolm.
Hi malcolm..its 76796533.
Ive got the abs light on after ive changed that trailing arm,the arm inc hub,caliper etc came off a mk1 but mines a mk2,abs light is on now,do you know if the set up on the hub is different as to be honest i cant see the sensor being at fault but who knows
paul
paul
here is price and part No. for the gaiter and clamp
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000527264 CYLINDER BOOT 6.11 GBP 7.33 GBP 7.33 GBP
00005280T6 BOOT CLAMP 7.90 GBP 9.48 GBP 9.48 GBP
and here is part No.'s for MK1 and 2 ABS sensor's
4545 87
ABR SENSOR
AR
- UNTIL RPO 09527
4545 A5
AR
- SINCE RPO 09528
4545 87
ABR SENSOR
AR
- UNTIL RPO 09527
4545 A5
AR
- SINCE RPO 09528
Regards, malcolm.
malcolm,because ive put a earlier hub on will that make abs light come on,am i best changing to the hub of the original one back on the car?..just with it being 2 different sensors thought they may be 2 different hubs with different abs rings
i dont know what difference there is between the two different ABS sensor's,crosser69 wrote:malcolm,because ive put a earlier hub on will that make abs light come on,am i best changing to the hub of the original one back on the car?..just with it being 2 different sensors thought they may be 2 different hubs with different abs rings
so cant really answer that one without looking at both setup's/sensor's
did you get the sensor with the S/H arm and is there any visual difference you can see,
if you dod get the sensor with the arm, it is possible that sensor is US
the two main things i can imagine could differ are the plug/wire config, and the mounting point,
the air gap between sensor and toothed rotor is important
Regards, malcolm.
