PUG 407 HEATER BLOWER DOESNT BLOW,WHATS UP?
gazzas c5
Unread post by gazzas c5 »
Hi folks my 407 heater blower doesnt blow at any speed but the heating works hot and cold
how do i get the fan blower to work?
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
Xantianut
x 127
Re: PUG 407 HEATER BLOWER DOESNT BLOW,WHATS UP?
Unread post by Xantianut »
Ay up, gazza!
First off, check the fuses. Replace any "blown" ones. Then locate the fan relay and change that for a new one.
If that doesn't work then you will need to swap the heater control board. I had to do it on a BX a few years ago and, while the part is fairly cheap, fitting the blasted thing is a world of pain. Good luck if this is needed!
While you're at it, it may also be worth checking the motor. Simply put 12v across its terminals and see what happens. Replacing that is harder than the control panel because I am sure that when a car is built, the tie the heater box to a rope hanging from the factory roof then build the car around it!
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
x 94
Unread post by citronut »
if its like my fiends 307 the plug at the blower/resistor pack had several overheated terminals,i cleaned and tightened them all up, and its been fine since,
i belive the pug dealer recommends a new heater loom
Regards, malcolm.
dieselnutjob
Unread post by dieselnutjob »
this happened to my 607 last winter (or maybe the one before?) in torrential rain and caused me to crash because I couldn't see anything :cry:
still it only cost me a suspension arm and a wheel arch liner so not so bad
it rained so hard that water dropped into the fan motor housing and collected in the bottom of the motor. After a few hours it started working again. I have now drilled a larger drain hole in the bottom of the housing... and put a new pollen filter in (it seems it keeps rain water out as well as pollen)
x 94
dieselnutjob
its usually blocked bulkhead drains or the plastic scuttle not sealed against the windscreen that causes water to enter were it shouldn't
Regards, malcolm.
