Mk 1 C5 Radio Code ?
Graham55
Unread post by Graham55 »
Found conflicting advice on this.
i'm about to fit a parrot car kit to my Mk 1 C5 Exclusive.
I don't have a radio manual with the car - does it have a radio code. I don't want to disconect the power to find I need a code.
Graham
Jabo
Re: Mk 1 C5 Radio Code ?
Unread post by Jabo »
I've disconnected my battery plenty of times and never needed a radio code.
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
x 1056
Unread post by wheeler »
Definitely no radio code on any C5 models.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
C5 radios are coded to the car... This means that if you disconnect it, theres no need to enter a code, but you do need to wait after a connection for everything to sort its self out.
Its also a good bargaining tool for a breakers who think you need to obtain a code, If you have a lexia with a friend, then the car only needs connecting up and telling that you have swapped the radio...
A very sad...
1994 XM 2.1 d auto
Graham55
Thank you all, will fit Parrot kit next weekend
Graham
BX
x 19
Unread post by BX »
When fitting the Parrot kit do not take the power from the radio. Take the +12V ignition power from the cigarette lighter socket and the permanent 12V supply from the 12V accessory socket behind the gear lever. If you use the radio supplies the BSI will detect the power drain and the car will keep going into eco mode.
