Got a flat towards the end of a long journey, no error message. Took the offending wheel off and replaced with spare, still no error message.
I though if the sensor was not working this in itself should give me an error message, so it just seems strange that no error message at all through this series of events has shown up.
Is this good news in that I can just have normal valves fitted? Any ideas what's going on?
Tyre pressure sensors
waynedance
- x 8
Re: Tyre pressure sensors
Are you sure you have the sensors fitted? Should be able to tell from the look of the valve stems, sensors have a metal cap that screws down.
I get a message when approx 6psi has been lost, maybe they have been disabled.
Volvo S80 D5.........
xenton
Have just notice the back ns has a normal valve but the rest have sensors, so must have been disabled in the past.waynedance wrote:Are you sure you have the sensors fitted? Should be able to tell from the look of the valve stems, sensors have a metal cap that screws down.
Mark D.
2001 C5 2.0 HPi exec.
SaabC5
And the spare won't have a sensor at all so it can go on either axle in the event its needed.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
spider
- x 77
I used to change a lot of these a few years back as the different metal used in the cap vs the valve itself led to corrosion and a stuck cap = expense. We used to just put normal black plastic ones on instead of the chrome ones when the customer asked too.
Might well of been resolved, I'm sort of talking 2000 to 2006
Andy.
xenton
I realise that, but I thought removing the flat wheel and it's sensor would cause an error message.SaabC5 wrote:And the spare won't have a sensor at all so it can go on either axle in the event its needed.
Mark D.
