new clamp or new exhaust?
john
Unread post by john »
not related to my other thread http://goo.gl/jBazB" onclick="window.open(this.href);return false; (well maybe indirectly), should their be a clamp on the join or is is welded? pics is the cat to mid section, i cant see how a clamp would create a seal as there is no slots for a clamp to pull together.
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Xaccers
x 188
Re: new clamp or new exhaust?
Unread post by Xaccers »
Clamp, like one of these
DIY sphere tool
john
so how does it close up when there are no slots?
should the lip of the pipe sit in the middle of the clamp?
Subaru Impreza WRX
Nissan Primastar
Mandrake
x 695
Unread post by Mandrake »
Yes.
The clamp edges have 45 degree slopes, and so do the flanges on the pipes, so when you tighten the clamps it pushes the two pipes together axialy.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Diabolical
Unread post by Diabolical »
john wrote:so how does it close up when there are no slots?
Clamp can be a sod to fit, however pulls 2 flanges together, horrible design but that's how they are.
New clamp would keep it good for while longer.
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
john
many thanks, just have to source 1 now.
Subaru Impreza WRX
Nissan Primastar
x 94
Unread post by citronut »
if this joint is forward of the CAT you must not put any jointing paste in the joint, but if it is rear of the CAT you can smear some jointing paste in the bell end of the joint to help it seal when pulled to gether,
i find flange joints better the slot together joints
Regards, malcolm.
x 94
ps.
check here for your car to find the Bosal part No. then go to your local motor factors with that
http://www.catalogue.bosal.com/pages/ex ... Berlingo+I" onclick="window.open(this.href);return false;
Regards, malcolm.
john
yeah its after the cat, my citroen dealer opens at 8:15 so will give them a call, according to the citroen service it should only be £5-6.
Subaru Impreza WRX
Nissan Primastar
