mani-to-cat gasket
john
mani-to-cat gasket
Unread post by john »
the wire mesh gasget and springs etc
when i got my berlingo if had gas leak from the mani-to-cat, having a look i noticed the one of the bolts was lose, tried to tighten it but couldn't, so got another kit fitted and all was fine - for a couple of weeks, its now leaking again! the nuts cant be tightened any more, what can i do? its driving me bonkers! :evil:
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
x 8422
Re: mani-to-cat gasket
Did they replace the 'brillo pad' gasket around the manifold spigot? Very important to do this as it compresses and also it needs to be installed with care. Also, the cups that sit in slots on the manifold flange need to be replaced too. These are a bugger as they're often rusted in but over time they deform and allow the bolts to protrude too far.
It's correct the nuts go so far and stop. The sequence of assembly is this: Manifold Flange Cup - Spring - 'Asbestos' Washer - Spring Cup - nut.
Lots of garages will short-circuit replacing the 'brillo pad' and manifold flange cups and hope for the best as it's a far from easy job...
No exhaust paste must be used around this joint whatsoever.
john
thanks, should have stated that i replaced the whole lot, brillo, cups, springs, nuts and bolts.
Subaru Impreza WRX
Nissan Primastar
x 8422
john wrote:thanks, should have stated that i replaced the whole lot, brillo, cups, springs, nuts and bolts.
Ahh right. Genuine or pattern parts?
john
pattern.
Subaru Impreza WRX
Nissan Primastar
x 8422
Might be a good idea top try a genuine set. Some pattern exhaust stuff is of very questionable quality and utility...
john
ok, also noticed the cat is a "Walker", does this mean its been replaced and possibly making it more difficult to get a tight seal?
Subaru Impreza WRX
Nissan Primastar
