This one is new!
The battery has just failed on my C5. Luckily, i still had the receipt for it so got it replaced however, I have noticed that the Air Con and also the Auto Headlight setting now do not work??
I have tried disconnecting the battery again and the Air Con fires up for about a minute but then goes off, none of the controls do anything.
C5 Air Con
corsehf
C5 Air Con
Andy
2003 C5 2.2HDi Exclusive SE Est
2001 C5 2.2HDi SX Est (gone to C5 Heaven!)
2001 Omega 2.2DTi Est (stolen by Ex!!)
1997 Xantia 2.1TD SX
1994 ZX TD Volcane
Lancia Stratos Replica
1994 ZX TD Volcane
corsehf
Re: C5 Air Con
Just as a reply and for no known reason? but the above problems have righted themselves, the air con became intermittent but slowly stayed on longer & longer and now seems ok?? -
Go figure?
Go figure?
Andy
1994 ZX TD Volcane
1994 ZX TD Volcane
corsehf
Re: C5 Air Con
OK, talking rubbish as normal!
The air con had gone all intermittent again last week and by the weekend has now given up the ghost.
However, when i say air con, it could be a blower issue - there is no demist option now neither.
The control panel says everything is working except for the blowers, i can just about feel heat or cold air coming from the vents but there is no blow (or sound).
Would this be just a rheostat issue??
All from a dead battery or just coincidence??
Andy
1994 ZX TD Volcane
1994 ZX TD Volcane
eddyc
Re: C5 Air Con
My first c5 did similar with the blowers and it was a stat or something in below the glove box, it was a we black box not much bigger than a matchbox and easily replaced cost me 45quid for the part and the mechanics time, the mechanic told me at the time it's a common fault so it may be a coincidence.
Sent from my GT-I9000 using Tapatalk 2
Clogzz
- x 40
Re: C5 Air Con
The battery isn’t to blame, the blower just carks it like on the Xantia.
The wires or the transistor need resoldering.
Can’t find a relevant topic, but this one is close:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=37343" onclick="window.open(this.href);return false;
