Hi, I have just been throught the car wash and found water dripping from the glovebox!!!! I think I could hear water swooshing around and now I am wodering if it is a blocked drain or something, OR something worse??? Is it a common fault??
Paul
Scenic Mk II Water ingress
wrinklet1
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
R9UKE
- x 3
Re: Scenic Mk II Water ingress
Scuttle drain at the bottom of the windscreen will be blocked at both sides. There will be a good 10 litres of water sloshing around in there and finding it's way inside! I've had to do this on all of my Méganes but never a Scénic to can't advise on how to gain access, sorry
(The well is under the plastic strip along the bottom of the windscreen)
French is best.
wrinklet1
thanks for he reply, I had looked under the wiper trim and like you say, both drain holes were blocked. Easily sorted and got me away from the wife for a couple of hours too.....
