1.9td tensioner spacer missing
davidc
(Donor 2021)
Unread post by davidc »
Hello
Recently changed the aux belt tensioner for my 1.9td 97 Xant. All went well thanks to info on this site though I found that I had to remove the HP and ECU to be able the see the damned thing and actually get access. However when dismantling the tensioner assembly I couldn’t see any spacer at the top of the spring shock absorber as shown as number 30 in the diagram. Diesel xants are very rare here in AU, the factory only brought in 200 so collective memory of the job here is very limited. Can anyone describe what it looks like, location, dimensions or even a pic?
2007 C5 hdi Wagon
74 D Special
2009 Mercedes Benz ML 320 cdi
Xaccers
x 188
Re: 1.9td tensioner spacer missing
Unread post by Xaccers »
I beleive 30 goes into the back of the cradle so nothing to do with the tensioner.
See its line in the pic points to the back of the cradle? 31 goes through the cradle and 30 then the engine block.
DIY sphere tool
x 8418
Indeed, 30 is just a dowel to locate the cradle on the engine block... So - no worries :)
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ill third that too.. nothing to worry about if you have not removed the cradle ..
A very sad...
1994 XM 2.1 d auto
davidc
(Donor 2021)
thanks guys!
2007 C5 hdi Wagon
74 D Special
