Changing a windscreen on a 406
cox377
Unread post by cox377 »
Hello guys,
Cracked the windscreen on my 406 but I've got a perfectly good one on a scrapper. Anyone changed one before?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I've done a 605. We sawed out the old screen with the wrapped type cutting wire and toggle grips, on the pillars and across the top. Bottom edge was knifeable.
It helps to have panel horses or similar around for cleaning up the reclaimed glass on.
x 94
Re: Changing a windscreen on a 406
Unread post by citronut »
before taking the cracked one from the car your useing i would either try removing or get a screen guy to attempt to get the one out of the scrapper,
as its not 100% it will come out in one piece
Paul at PBW on 07976328765 he is a good windscreen fitter he also does recovery jobs evening and weekends,
reasonable rates
if you try him tell him malcolm recommended him
and he is based in Hailsham
Regards, malcolm.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
I tried removing a 605 once, cracking job ;)
gutted as I even paid £20 for a tool to help...
