C5 Heating issue
fosseym
C5 Heating issue
Unread post by fosseym »
Hi All
I have a 2004 C5 HDI Exclusive with aircon and climate control - when the blower is on and the temp is low the passenger air vents blow hot and the drivers cold
Help !!
peterdk
Re: C5 Heating issue
Unread post by peterdk »
This issue is very known and by using the search function, you can find the answer. The procedure to fix your problem is quite time consuming, as you need to remove the dashboard...
SaabC5
Unread post by SaabC5 »
peterdk wrote:This issue is very known and by using the search function, you can find the answer. The procedure to fix your problem is quite time consuming, as you need to remove the dashboard...
No you don't, you just need to remove the glovebox. See the link below for the cure...
http://www.frenchcarforum.co.uk/forum/v ... hp?t=32780
Clogzz
x 40
Unread post by Clogzz »
http://www.frenchcarforum.co.uk/forum/v ... hp?t=32780" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... hp?t=36678" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... hp?t=37149" onclick="window.open(this.href);return false;
http://www.aussiefrogs.com/forum/showthread.php?t=89911" onclick="window.open(this.href);return false;
peterdk
Awesome, I heard it was a much worse job :-)
