Axle Stand Locations - Citroen Xsara
dandare1980
Unread post by dandare1980 »
I thought I had better start this as a new post, but this is relevant to a clutch change if that makes any difference.
Where on the front of the car is it safe to place axle stands so the front of the car can be lifted clear off the ground?
The Haynes manual suggests jacking under the centre of the front subframe using a block of wood to protect it from the head of the jack, then resting the car down on the jacking points on the sills.
I know on the rear of the vehicle you can jack up in the centre of the rear axle tubular crossmember and use the sill jacking points or the crossmember itself for the stands.
How high do I need to be to allow clearance for the gearbox removal?
Any practical advice most welcome.
Dan.
1998 Citroen Xsara 1.9 D Estate (XUD9A indirect injection engine DJY with Bosch XUD 211 injection pump).
oneday
Re: Axle Stand Locations - Citroen Xsara
Unread post by oneday »
place stands under the sill jacking points one each side is enough. the gearbox does not need to be removed there is enough room in the engine bay to move box to one side and have enough room to replace the clutch
306 1.4 LX MERIDIAN
dandare1980
Thanks oneday, that would be truly super if I don't have to drop the box out of the engine bay.
