ax fuel gauge
meexi
ax fuel gauge
hi the fuel gauge of my ax 1.4 diesel mk2 is always showing full wenever i put on the `ignition` switch. when i take the wires of the tank sender it is still at full . any ideas?
AndersDK
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> when i take the wires of the tank sender it is still at full <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
- might exactly be the clue you need :
You have in fault tracing logic terms - what is called a "no-change" situation.
This may mean a wire/connector is allready disrupted = no change at all removing the tank sender connector.
but where to find it - well - advice can be given over cyberspace - but not manual work [:D]
