A few things please
There is a rattle on the o/s/r that i've tracked down to be a loose washer on the bolt from the ARB onto the arm (18mm head) I've tried to do the bolt up but i can't shift it, i've not give it any serious abuse yet but is this bolt a troublesome one or am I ok to not be a school girl and get the big bar out....
Also my cruise doesnt work but i've got no voltage to pin9 which from what i can see comes via a relay ( brake pedal contacts are now ok) where is this relay?
One last thing, the rear brake pads rattle a little bit (just had new pads and discs fitted) I presume that once they've worn a bit they'll be ok?
Cheers
XM Gurus..
Chris570
- x 36
XM Gurus..
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 1240
Re: XM Gurus..
You will probably find that the drop link needs replacing, they wear for a pastime. Give the threads a good wire brush and some oil before you try to undo them, if the stud goes round with the nut, put some stress on the joints by jacking up or lowering the side you are trying to undo, if that doesn't work use a crowbar to load it. Once you have the nuts off they are quite easy to change.
Can't help with the cruise I'm afraid, none of mine had it.
- x 94
Re: XM Gurus..
do XM's have drop links on the rear anti roll bars then,
rear pads maybe cheap aftermarket pads were fitted which are not quite tight enough in the calipers,
otherwise the end of the calipers were the pads run are worn with age allowing the pads to rock end to end
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Re: XM Gurus..
Lol.. I thought that too malc.no drop links on the rear at all... the rattle is the anti roll bar however chris its a captive nut and can shear off inside the arm.. this happend on my v6 Sei and ive not sorted it. Im having to resort to changing the whole aubframe as by the time it gets to a rattle its toooo late.. threads buggered..
as for pads.. was the U ahaped spring that tensions on the pad bolt re fitted?? its the only thing that stops them rattleing.. it sounds like one has been left out...
the relay on s1 cars is sitting on the front of the ecu box with a few others.. useually next to the silver cruise box.. Not certain on late s2 cars though... sorry..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1240
Re: XM Gurus..
Sorry, I'm getting confused in my old age
the last pair I fitted were to the 406.
Chris570
- x 36
Re: XM Gurus..
That doesnt sound good at all...citroenxm wrote:Lol.. I thought that too malc.no drop links on the rear at all... the rattle is the anti roll bar however chris its a captive nut and can shear off inside the arm.. this happend on my v6 Sei and ive not sorted it. Im having to resort to changing the whole aubframe as by the time it gets to a rattle its toooo late.. threads buggered..
is this something i can gently remove and then re-tap the threads?
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
citroenxm
- Fallen Hero
- x 70
Re: XM Gurus..
Im not sure chris.. when my v6 sei first started i tried tightening it up but failed.. i cant remember now if i tried undoing.. i may have but failed. I resorted to swapping the whole frame from another which i have lined up now.. .. just need to get the arse in gear and do the work...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Chris570
- x 36
Re: XM Gurus..
Or, i could just leave it alonecitroenxm wrote:Im not sure chris.. when my v6 sei first started i tried tightening it up but failed.. i cant remember now if i tried undoing.. i may have but failed. I resorted to swapping the whole frame from another which i have lined up now.. .. just need to get the arse in gear and do the work...
sod changing the subframe
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
citroenxm
- Fallen Hero
- x 70
Re: XM Gurus..
With something as quiet as an s2 esj engine it will annoy the pants off you.. it would me and did me with a Prv S1... a subframe change is not hard.. only four bolts to get the frame off and 5 pipes to disconnect... plus the height lever rod plus remove the exhaust..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
andmcit
- x 30
Re: XM Gurus..
Seems a bit extreme swapping a rear subframe because the trailing arm has got a duff thread Paul?
The arm is easy enough to swap over if a bit time consuming though. I've known these ARB bolts snap
on Cx 's but not Xm or Xantiae.
Nothing moves you like a Citroën
citroenxm
- Fallen Hero
- x 70
Re: XM Gurus..
Yes i know andrew but you cant get the arm out if the roll bar bolt wont come out!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
Re: XM Gurus..
thats because the CX arms are alloy,andmcit wrote: I've known these ARB bolts snap on Cx 's but not Xm or Xantiae.
Regards, malcolm.
addo
- Sara Watson's Stalker
- x 95
Chris570
- x 36
Re: XM Gurus..
I've found the cruise relay now
as for the rear ARB i suspect that it may be a carefully remove and retap job
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
addo
- x 95
