So, what filters do you guys use on your beloved vehicles?
Do you have a certain preference? Do you hate Fram, or is it a case of Fram or nothing? Or do you just use whatever they have on the shelf at the time?
I don't have much of a particular preference. They are mostly made in the same factories anyways, or at least using the same tooling. I don't hate Fram. Although there are stories of all types of terrible things happening with Fram filters, its never happened to me.
The only preference I have is I try to find filters with a non-return valve. Often cheaper pattern filters don't have one of those, and it means the oil galleries of your engine slowly drain, whereas filters with a valve prevent that.
Whats your favorite brand of filter?
Citroenmad
- x 110
Re: Whats your favorite brand of filter?
I always get genuine Citroen filters, for a few reasons ... With the metal type ones you can see it and so its badged Citroen ... They are the proper ones and so I dont have to worry about getting a cheap or filter which could be better. However, I usually try and pick them up at Citroen events at trade stalls, which means I dont often have to pay full price for them.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Northern_Mike
That option. Whatever's there. I'm not sure filters are massively important these days, with such good oils and quality of materials and manufacturing techniques used in building modern engines. I think the oil itself is important, as the turbo failures in the smaller HDi motors show - gummed up oil feeds, turbo fails. Nothing to do with the filter at all. Stupid design maybe.nametooshort wrote:So, what filters do you guys use on your beloved vehicles?
So, I just use whatever is there. At the moment, I use dealer bits, because the dealer is but 3 miles drive away, and is closer than any other motor factor..
