I have travelled back from Wales to Hertfordshire today and I've noticed a whinning noise from the front end. It sounds like a wheel bearing on its way out, as i took it out of gear and you can still hear it. I was wondering if anybody has any idea roughly how much this will cost in a garage?
I would give it a go and replace it my self but don't have access to a press.
Cheers
Xantia HDI estate wheel bearing
Re: Xantia HDI estate wheel bearing
remove the hub take it to a local indy they should put the new bearing in for a few quid
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- My Cars: 2001 Xantia 110 Hdi Forte estate - owned from new.
1984 2cv Special
Various modern crap!
Top tip - seems its rarely the side you think it is! Normally, bearings hum more when under load, hence right hand bend, if louder - left hand bearing suspect. Doesn't seem to work like that on Xants for some reason - the 'cassette type' bearings seem to be noisier OFF load - but I'd recon on doing both, then if you get the right one first time its a bonus!
N
N
good plan glad i could be of some help to you happy spannering good luck
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
