Xantia poor acceleration
froggy
(Donor 2026)
x 4
Unread post by froggy »
Hi, I am finding my 1997 TD, Xantia, has very poor acceleration from second to third. My Xantia is now heading towards 180,000, should I exspect this sort of acceleration because of the mileage? anybody got any thoughts or ideas. many thanks in advance Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Xaccers
x 188
Re: Xantia poor acceleration
Unread post by Xaccers »
No you shouldn't expect it.
Check you've got no boost leaks from the induction pipes, make sure they're all tight.
Also check the boost pipe to the UFO on the pump for splits, it might be time to replace it.
When did you last replace the air filter?
DIY sphere tool
froggy
(Donor 2026)
x 4
Sorry to sound thick, but what is the ufo ? changed air filter last summer ! whoops!
Terry
x 94
Unread post by citronut »
its the large capsule ( UFO shaped unit ) on top of the fuel pump,
as Xac says check all vac/induction/intercooler pipes/ducting for leaks/cracks and not fitted tight ( jubilee clips done up tight )
Regards, malcolm.
Xaccers
x 188
froggy wrote:Sorry to sound thick, but what is the ufo ? changed air filter last summer ! whoops!
Get the air filter changed!
Probably an idea to change the in cabin pollen filter too, won't help with the car's performance but It will make the cabin smell nicer and the blower work less hard.
DIY sphere tool
froggy
(Donor 2026)
x 4
Ta.
Terry
