Its taken 11k but ive just come home and niticed splaters of lhm inside the drivers front wheel rim, and drips on the outer edge of the subframe along with soaked undertray in the area and splatters all over that side of the engine bay although there are spots all over the engine tbh, pump is dry though, not very well atm either so not really got the energy for it, any clues as to what it could be before i get out there tonight gents?
D
Activa throws its toys
Deanxm
- x 87
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Xaccers
- x 188
Re: Activa throws its toys
Could it be return pipe popped off the dosuer valve?
DIY sphere tool
DIY sphere tool
Deanxm
- x 87
the leakage seems to be coming from the front crossmember and blown back down the subframe past the P bush but i will get over the back and have a check first Xac thanks, there ia oil in the rads because i can smell it and its sprayed up the side of the ecu box too but you know what LHM is like it goes everywhere.
D
D
XM Prestige PRV6 92
- x 1481
not just the strut return hose?
addo
- Sara Watson's Stalker
- x 95
Deanxm
- x 87
Thanks for the help guys, i had a look this morning and its the main pump to pressure regulator feed pipe that has burst spraying a fine mist across the front of the engine and into the rads, i will put a seperate post up but if someone has one i could do with one asap.
D
D
XM Prestige PRV6 92
Chris570
- x 36
I'm sure i've got a spare one.....
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
oneday
your right i saw it aswell think it was from handyman
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 8450
Yes, the post in question is down in the For Sale/Wanted area ...oneday wrote:your right i saw it aswell think it was from handyman
Dean, sorry to hear this
