My cousin has bought a cheapy little Xsara as a run about, its a nice little motor but the cable seems to be really sticking, ive offered to assist him to fit it, wonder what kind of a job it is, ive done them before on older cars.
Cheers!
2000 Xsara 1.4i Clutch Cable
tim leech
- x 12
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
spider
- x 77
Re: 2000 Xsara 1.4i Clutch Cable
If its the same as the 306 its not bad at all really. Be aware it may pass between the AC pipe work on the bulkhead area, this looks impossible to do (it won't fit!) however you can undo a bolt and the bracket on the pipework will move, allowing the pipes to move, not much about an inch but its enough.
Caution: Don't undo the nut where it goes into the bulkhead area, this is the clamp holding the pipes on (!) its a bracket bolt you are undoing. If in doubt don't undo it. I seem to think the bracket bolt is on the inner wing area, possibly via the wheel arch. Trouble is these things / locations do vary between a 306 and a ZX / Xsara.
Book time is about 0.7 or 0.8 if I remember correctly, so allow a good hour if you've not done one before.
Generally its OK, a bit of a fiddle to get the end on the pedal but apart from that OK. 99% sure its a self adjusting cable on these too.
Andy.
