Xantia Front Struts Removed - Any good??
gadgetgricey
Unread post by gadgetgricey »
Well finally got the front struts off the Xantia I was breaking, but not sure if they are any good?
Also I learned the hard way regarding removing the drive shaft nut, so that's still attached to the first one I removed :oops:.
Was planning on selling them, but if they are both poor, dont want the hassle of striping them down
Both removed from a Xantia 110 Hdi Estate.
Link to pictures here
Opinions please.
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
x 94
Re: Xantia Front Struts Removed - Any good??
Unread post by citronut »
the strut tops look cream crackerd but that doesnt mean the truts them selves are not useable or even the hubs and drive shafts
Regards, malcolm.
handyman
Unread post by handyman »
Dave, do not scrap the strut tops. I'll 'ave 'em, as I am amassing a collection of these to be repaired by my 'rubberman' here in the UK. Already have a couple of samples on test and they seem to be working OK. Still looking for a C5 version, in any condition.
Front struts rarely give any trouble, even on higher mileage cars.
Handyman
Xantianut
x 122
Unread post by Xantianut »
Ay up!
How much for a pair of Xantia tops, and is DIY fitting an option?
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Strut tops are fairly easy to change.. and fairly DIY able with a bit of Citroen knowledge...
Ive a few Xantia TOPS in bad state that need to goto a re furb to hold a stock of tops. I dont bin any of them..
Dave, its not that TOP side thats as important as the side you didnt take many pics of.. Its the rubber on the under side where the strut BOOT attaches under the top thats important, its its started to split then they are bad... The metal plates still look reletavly OK.. Yes NOT perfect, those are some of the worse S2 tops ive seen so far. But some pics of the "Under Side" would be good...
A very sad...
1994 XM 2.1 d auto
gadgetgricey
Must admit did not realise the top bits were removable :oops: :oops: .
Wife's Birthday tomorrow, so doubt I'll be able to get the spanners out, but will try and have a look Friday, and get some additional pics.
Thanks again all.
- Dave -
Citroenmad
x 110
Unread post by Citroenmad »
handyman wrote:Still looking for a C5 version, in any condition.
Handyman
Is this to refurb them or to try on a Xantia? Ive not heard of any C5 tops failing ...
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 94
citroenxm wrote:Strut tops are fairly easy to change.. and fairly DIY able with a bit of Citroen knowledge...
although the base plate can fail all the tops i have seen let go its been the domed section above the inner wing that has broken,
as in one of those picy's the dome is breaking up
Regards, malcolm.
citroenxm
Fallen Hero
x 70
And its the rubber underside that tells all.. you can see the rubber seperate from the base plate which eventually allows them to pass each other..
my xm stops were in a bad way. should make a sticky post on it.. the base plates were fine but the rubber under the bottom side where the strut connects was pushing out downwards as lookong up under the wing..
the result when i took it off the car was scarey...
A very sad...
1994 XM 2.1 d auto
