Ay up!
Our latest project. We've worked out the head and all that but how does the crank pulley go back together? Its in two bits and has no apparent fixing between them, nor any reference point for the timing!
Anyone able to help?
1.4 16v Megane snapped cambelt - Torque settings, pls?
Xantianut
- x 127
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
RIP
BX19DTR (Fifi 2)
Lighty
- x 34
Re: 1.4 16v Megane snapped cambelt
Not sure on the crank pulley, but the crank shaft has to be set using a special pin through the front of the block.
Have a look at this, good drawings
http://www.tooled-up.com/artwork/ProdPDF/VS4960.pdf" onclick="window.open(this.href);return false;
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Xantianut
- x 127
Ay up!
Thanks for that. Lighty. Camshaft locking set on order.
RIP
BX19DTR (Fifi 2)
RIP
BX19DTR (Fifi 2)
Xantianut
- x 127
Ay up!
Camshaft locking kit - check. Valves installed - check.
Anyone know the torque setting for the head bolts?
RIP
BX19DTR (Fifi 2)
RIP
BX19DTR (Fifi 2)
Xantianut
- x 127
Re: 1.4 16v Megane snapped cambelt - Torque settings, pls?
Ay up!
Haynes manual obtained from the local library.
As for the torque settings:
RIP
BX19DTR (Fifi 2)
RIP
BX19DTR (Fifi 2)
