blower sound
IrfanIbrahim
blower sound
Unread post by IrfanIbrahim »
there is a loud sound coming from the ac blower. What could be the problem?
1994 Xantia 2.0I
Keep calm & drive a xantia!
x 1238
Re: blower sound
Unread post by Peter.N. »
What sort of sound?
IrfanIbrahim
Re: blower sound
idk how to explain the sound #-o
but ive suspected that some object had got into the blower. is it possible for this to occur?
1994 Xantia 2.0I
x 1238
Re: blower sound
Probably best to take the blower out and have a look, its only held in with three screws, take the panel off under the glove box and you will see it, its not difficult to remove.
IrfanIbrahim
Re: blower sound
Okay i will take a look. Thanks.
1994 Xantia 2.0I
IrfanIbrahim
Re: blower sound
surprisingly, the sound come from a rubber band! (i dont know how it get in there) :lol:
1994 Xantia 2.0I
x 1238
Re: blower sound
Ah well, pleased you found it anyway.
jgra1
(Donor 2021)
x 36
Re: blower sound
Unread post by jgra1 »
my C5 fan is making an very annoying squeal, whistle almost.. it is ok on the lowest levels, and max.. but anything else almost unusable..
can I get at it as easily? maybe add a bit of WD in there...>? :)
x 1238
Re: blower sound
Haven't had a problem with mine - yet, but if its the same as the XM its above the passenger side foot well.
