Going to be replacing them at some point in the near future. Anybody got any tips?
Xantia driveshaft seal replacement
mirafioriman
Well sick of oil leaks from the gearbox so finally got round to getting some new seals from my local Citroen dealer
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
citroenxm
- Fallen Hero
- x 70
Re: Xantia driveshaft seal replacement
Would of thought it being straight forward.. the half shaft bearing will either be a right sod to get out or will pull out nicely with a gentle tap.. make sure the "hocky stick" bolts are undone and swung out the way.. the 11mm nuts dont need to come off completely just undo them to the ends then push the bolts forward and turn them 90deg....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
mirafioriman
Thanks, good tip with the bolts
