Xsara Picasso Clutch gone!
PicassoPigeon
Unread post by PicassoPigeon »
Clutch was making a strange noise last week, sort of click/clunk as you push the pedal down... :evil: Well this morning, stopped at a set of lights and I couldn't get into 1st gear, had to drive back home without clutch :evil: , good job it was only around the corner.
Any idea what sort of price I should be paying? And what would be the best make?
Cheers
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
x 1480
Re: Xsara Picasso Clutch gone!
If you want to keep it, then fit a Valeo or LUK clutch (I suspect Valeo is OE spec) - carparts4less have got LUK ones listed at £85, aepdirect Valeo ones at £125. If you hate it and yourself, save £20 by fitting a Transmech clutch :) Probably 5 or 6 hours labour, depending on what is rusted up - so figure in £300 or so for that. Add in a bit for gear oil, diff seals, input seal, and pivot shaft bushes if you do it properly and you are looking at the thick end of £500. Worth doing on a Picasso if it's otherwise reasonable - they are holding their value pretty well.
At least it's not a 1.6 HDi, as the clutch job on those is reportedly horrible....
x 94
Unread post by citronut »
as its a 2.0 HDI i may have a DMF in which case being the 2.0 cit/pug do a conversion kit back to a solid flywheel,
a replacement DMF is around £400 quid from GSF and a lot more from the dealer
Regards, malcolm.
Lighty
x 35
Unread post by Lighty »
All Picasso 2.0 are 90 bhp, so no DMF in this case, just a straight forward clutch replace, not that easy on Picasso.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
PicassoPigeon
Thanks guys...time to lighten the wallet!
125,000 miles
flying clutchman
x 3
Unread post by flying clutchman »
Around £300 all in is the sort of money you'd expect to pay. It's not the worst clutch to do, but I wouldn't attempt to diy unless you've done something similar before.As someone else said the 1.6hdi is a real pig and that HAS got a dmf fitted.
PicassoPigeon
Clutch all done, went in to local garage that my taxi driver mate uses. £295 using a LUK clutch. Very happy and oh sooooo light! :)
125,000 miles
