Hi
I need to change a rear coil spring on our c4 hatch (2005) and wondered how you get the old spring out? I have spring compressors etc, do I need to unbolt the top of the damper on both sides to let the rear axle down further?
C4 rear springs
gary
Re: C4 rear springs
With the vehicle up on stands, all you need to do is to place a jack under the rear arm remove the shock absorber lower bolt on both sides and lower the arm, the springs come out without using spring compressors.
