Locking wheel nut
hdi_man
Locking wheel nut
Unread post by hdi_man »
the garage have lost my locking alloy wheel nut. how much is it for a new one ??
x 1496
Re: Locking wheel nut
Bolt or key?
If the bolt then I would just fit a normal hex bolt... if the key then it looks like they are only available as a set and cost around £50-£60 depending on the age of the car - should be able to get a matching set to the ones you've got otherwise getting the other nuts off will be a PITA!!
acrowot
Unread post by acrowot »
Removed 1 locking bolt yesterday, it ony took about 15 mins. started with a 9mm drill and went up in 1/2 mm steps to 13mm and wheel fell off, the bolt was 12mm x 1.25 and as soon as the drill had gone in about 14mm untill it had gone through the bolt taper to the bolt diameter the wheel came off. I thought it would be more difficult but in the end was quite easy, good quality drill bits are needed.
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
waynedance
x 8
Unread post by waynedance »
1st thing I remove from my cars are the locking wheel nuts, they are a pain.
Volvo S80 D5.........
