Central locking but a weird twist
Neortic
Central locking plays up. Symptom is - remote attempts to lock but one door is not working. Thats ok will lock by key for now, hold key for a moment in lock position all doors lock. Drivers door at fault, check wiring between door and body, broken wire, youv'e all heard of this. Ok repair the one wire (grey) and..... Nothingat all. No attempt made at central locking via remote or key. Now have to lock doors manually. Also boot opens via button but does not lock via key or driving car. No immobiliser. Did find 2 broken wires on passenger door, but repairing no difference. All other features work. Any ideas, fixed wire made it worse!!!!
- x 8421
- x 94
Re: Central locking but a bit weird
what car is it
id check for more broken wires, maybe disturbed whilst you were in there, one side ir the other
Regards, malcolm.
Neortic
Re: Central locking but a weird twist
Its a 1.6 xsara 53plate, perhaps should add, yes tried undoing the repair and no did not revert
- x 94
yep broken/fractured wires
Regards, malcolm.
Neortic
Thanks, hope that's all it is, no chance of anything more serious then?
