C2 air bag warning and intermittent horn
Bannedbiker
x 3
Unread post by Bannedbiker »
Hi everyone,
A neighbour as a "56" plate Citroen C2 (not sure of engine type or size).
She has had a problem for a while with the airbag warning light being lit and a warning on the central display on the dash.
Recently the horn has become intermittent in operation (works sometimes, doesn't at other times).
I wondered if anyone has had the same faults or whether they could be a common fault that is easy to fix [-o< .
Martin.
2003 Peugeot 307, 1.6 petrol.
Previously owned 1999 Citroen Xantia 1.9 td and a 1997 Citroen ZX 1.9
x 1056
Re: C2 air bag warning and intermittent horn
Unread post by wheeler »
They could possibly both be related as both of these things go through the COM 2002 (the wiper/lighting stalk assembly) but you would just be guessing at the airbag fault without getting the airbag system faults read first.
Bannedbiker
x 3
Thanks, I'll let her know.
Had a funny feeling about the stalk assembly as it seems that in 99% of times anything that goes wrong in that area the COM 2000/2002 unit is to blame.
I'll stick with my '99 Xantia and '97 Mx5!!!!!
Martin
