What's wrong with my CX - help please !!
minijohn
Unread post by minijohn »
I have a strange problem......
The CX ran fine (25 GTi auto) but I wanted to check the valve clearances. I removed the inlet manifold & whatever else was necessary to gain access, did the adjustments (not much) &
now I've put it back together it won't run properly.
It starts and revs up to about 2000rpm for a few seconds and then the revs slowly reduce - and then it stops.
It will start again immediately with exactly the same result.
If I press & hold the accelerator, it will run albeit a bit rough but not at low revs.
I've checked everything I disconnected & it's all back in place. There are no splits in the air inlet bellows (not sure what you call that bit) and if I remove that completely the car won't start at all.
From other stuff I've read I'm thinking it may be the air flow meter but I haven't touched it or even disturbed any connections in that area.
Any ideas anyone?
Thanks in advance
John
CGATCX25GTITURBO
x 16
Re: What's wrong with my CX - help please !!
Unread post by CGATCX25GTITURBO »
have you pulled the idle hose off the back of the air auxilary valve at the back of the engine, is the alternator charging the battery, is the temp sensor plug fitted ok on the back of the cylinder head
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
minijohn
SORTED !!!!!!!!!!!!
Hi
Thanks for the quick reply.
I checked those things & they were all OK.
One thing I did notice though is where the 4 rubber hoses join the plenum to the inlet manifold, I could see some of the serrations on the black plastic part which I'm sure I couldn't see before I took it all apart.
I checked the hose clips & they were all tight............that gave me an idea.
I then started the engine & kept it running by pressing the accelerator to get some heat in the engine.
Once it could tickover unaided I went back under the bonnet and sprayed carb cleaner on the joins of the 4 rubber hoses.
On numbers 2 & 4, the spray sent the revs straight up, indicating an air leak.
I've reassembled the joints and the car now runs much better but the revs will still rise when sprayed.
I think the rubber has had it - so I'll replace shortly - think I'll go for silicone
Thanks for all your help
John
