Hello I need to remove the door cards on the front. Ive taken the speaker cover of, 3 torx screws out 1 under switch window, other door handle then other near mirror.
The only thing holding the door cards on now is the door handle or surround?
Removing door card 306 hdi
spider
- x 77
Re: Removing door card 306 hdi
There's a screw under the grab handle at the top, more or less a couple of inches straight down from the mirror if that makes sense, might be a plastic plug in it. You'll see the plug / hole if its fitted anyway.
You've taken the window / mirror switch out and the screw there ?
Pulled the small trim off the interior release handle ?
There's one under the door grab handle at the back too, it goes vertically / straight up
Andy.
Welshy_Pete
Pulled the small trim off the interior release handle ? Thats the one I needed thanks for the help and information.spider wrote:There's a screw under the grab handle at the top, more or less a couple of inches straight down from the mirror if that makes sense, might be a plastic plug in it. You'll see the plug / hole if its fitted anyway.
spider
- x 77
You're welcome.
Andy.
