c5 alarm
Robert12
c5 alarm
Unread post by Robert12 »
C5 2.2 hdi estate the alarm keeps going off any known faults to look for?
x 5672
Re: c5 alarm
Under what circumstances?
If a window is open a light breeze can trigger the volumetric alarm.
Robert12
Re: c5 alarm
windows up all doors closed
waynedance
x 8
Re: c5 alarm
Unread post by waynedance »
I had this problem and it turned out to be the drivers seat belt slowly returning. Could be an hour before the belt decided to retract.
Volvo S80 D5.........
Citroenmad
x 110
Re: c5 alarm
Unread post by Citroenmad »
Try pressing the button to disable the interior sensors (you need to press and hold the button until the amber light appears) and see if it will sit with the alarm without going off. That way you can atleast pinpoint it to an interior sensor or perhaps something like waynedance suggested.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Robert12
Re: c5 alarm
Never thought it could be the belt retracting.why do the belts stick
x 5672
Re: c5 alarm
Belts in C5s suffer from slow retraction after a while.
A good clean sometimes does the trick.
Spraying them with a silicone spray helps but may have detrimental effects on the webbing.
waynedance
x 8
Re: c5 alarm
Robert12 wrote:Never thought it could be the belt retracting.why do the belts stick
I did not until I saw it happen, in the end pulled out all the belts fully and trapped them in the door so they were on the outside of the car and jet wasted the belts as they were dirty. The drivers belt now goes back fully straight away and alarm never gone off again.
If I had not seen the belt moving back after the car had been sitting for some time I would have thought it was faulty interior sensors.
SaabC5
Re: c5 alarm
Unread post by SaabC5 »
Belts get sticky and dirty with constant use, a bucket of soapy water and a sponge can cure this. Just pull the belt out to its maximum length and run the sponge up/down both sides of the belt. Leave them clipped into the buckles to dry and it normally sorts them out.
Robert12
Re: c5 alarm
thought we had cracked it but now it whent of 3 times today parked at work justs got in it going home and the buzzers going saying the boots open when its not is there a cencer on the boot for the alarm?
Robert12
Re: c5 alarm
replaced the tailgate lock to see if that makes a difference £26 from main steelers
