Hello everyone.
I've just bought my first CX (that seems to imply there will be more?)
I have a query about the tappets & I wonder if anyone can help.
My engine sounds tappety and I'm about to check the clearances. Using a screwdriver as a stethoscope, the noise seems to be coming from just behind the camshaft pulley rather than the rocker cover area.
The Haynes manual says that if the engine sounds tappety after adjustment, then the camshaft extension bearing may need re-adjusting.
Can anyone explain to me how that can be - surely the camshaft is fixed in position by 3 bearings - they're not adjustable or moveable - I don't get it.
Thanks in advance
John
CX25 GTi Auto - tappets query
Citroening
- x 19
Re: CX25 GTi Auto - tappets query
Welcome to the Forum John and great choice on the GTi Auto!
I'm sure someone with the correct answer will be along shortly however any more details of the CX for us CX Fans/Anoraks?!!
Can we tempt you to come along to the CX, XM and Xantia Rally on the 7-9th September? http://www.frenchcarforum.co.uk/forum/v ... 78#p321378" onclick="window.open(this.href);return false;
Welcome!
Welcome!
Franklin
CGATCX25GTITURBO
- x 16
Haynes have taken that from the factory manual and it is correct, however, depending on mileage and general servicing ETC... The rocker arms can and do wear; in effect the clearance is being adjusted using a thickness checker that is wider than the wear band (width of the valve stem) in the rocker arm and can be the more likely cause of the noise; as it doesn't allow for the hollow in the arm.
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
minijohn
Hi CGATCX25GTITURBO
Thanks for the reply, I can understand exactly what you're saying with regard to worn rocker arms but what I don't understand is how the camshaft extension bearing can somehow alter the position of the camshaft?
Citroening - I'll post some pics in the Introduction section shortly.
Rally is a maybe if the car's together & useable by then
John
John
CGATCX25GTITURBO
- x 16
Put simply the cam 'does' move a bit
Old tech motor, clearances as wide as you like; and a long cam like these can have a bit flex in it at the pulley end. I've seen them snap.
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
minijohn
Oh great................I've seen them snap.
In fact after adjusting the camshaft bearing & the tappets and replaced the 4 drivebelts, the car doesn't now run properly.
It has a misfire so I'll have to sort that - run out of time tonight.
John
