Hi All,
just had success with repairing a spare tailgate push button unit for a Mk.1 Xantia which had failed springs (common fault due to water ingress?). I managed to source an almost direct replacement spring from RS Components and they fit and work a treat. So I thought that I would pass on the info.
The springs are RS number 751-411 and come (unfortunately) with 10 in a plastic bag for £7.30 +V.A.T. and delivery (I did get them through a friend in the motor trade!)..But I thought that it worked out a lot cheaper than a new unit from Citroen...
From the RS data sheet...
Type Compression
Material Music Wire
Minimum Work Length 10.6
Rate 0.43N mm
Diameter OD 3.6mm
Free Length 25.5mm
Load Min. Work L. N 6.37
Wire Diameter 0.4mm
Approx. No Work Coils 18.5
just type in rs 751-411 into google...
Hope this helps...
Cheers
Glyn
Xantia Mk.1 Tailgate Push Button
bonnyman750
- x 3
Re: Xantia Mk.1 Tailgate Push Button
A quick update from Service.Citroen (unit not includiing key barrel)...
Part Number: 00008726V8 Description: TRUNK LOCK Quantity: 1 Price excl. VAT: 51.33 GBP Price incl. VAT: 61.60 GBP Total incl. VAT: 61.60 GBP
So £7.30 + V.A.T.+ Del. for 10 springs ain't bad...
Glyn
Glyn
addo
- Sara Watson's Stalker
- x 95
