Good news on the MOT front
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Just back from MOT with daughter's Xsara and a new ticket to go with it. Only one advisory which was for a misted headlamp. That's all four cars done for this year. But I would have been p*££ed off if the Xsara had failed because I've done a load of work on it during the past couple of months. New front pipe and cat, new heater motor, new rear discs and pads, four new filters, change of brake fluid and coolant, and a recon rear axle, and a couple of new tyres............................ Now regarding the misted headlamp. Is there a cure for it or is it a trip to the breakers?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Do you mean it has condensation inside it, or is the polycarbonate hazy?
JohnD
(Donor 2022)
x 72
Re: Good news on the MOT front
Condensation is on the inside of the lamp.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 8422
JohnD wrote:Condensation is on the inside of the lamp.
Given the weather it's not surprising... At this rate we'll all need amphibious vehicles soon..
Anyway, great news on the MOT record for this year John =D>
C5Alan
Unread post by C5Alan »
I had this on a Ka years ago I just poped out the indicator bulb and left her running with full beams on for about half an hour sorted it out. this should work the same if you take the cover off the back and drive around when its dry with the lights on the heat from the bulbs should dry it out just remeber to refit the cover maybe clean and check the seal on it too
2003 C5 2.0 HDi 110hp Exclusive only done 218,000miles so just about run in. Family owned from new. Now Sold
2002 Renault Scenic 1.9Dci 111,000miles the new work bus
x 1056
Unread post by wheeler »
Removing the bulb & blasting in the lamp with a hairdryer usually does the trick aswell.
JohnD
(Donor 2022)
x 72
Thanks for those tips. I'll try it when it stops raining.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
