2000 Xantia 2.0 - which octane?
MortyDK
Unread post by MortyDK »
Dear all,
I have just acquired a used Citroën Xantia 2.0 16v, first registered in the year 2000.
The original instruction manual didn't come with the car. I have tried to google which octane the car needs, but without luck.
Does this car need 95 octane petrol? Or can I safely drive on the cheaper 92 octane as I've been used to so far? :-)
Xantia 2000 2.0 16V 132 BHP petrol
Harry1975
Re: 2000 Xantia 2.0 - which octane?
Unread post by Harry1975 »
i should say on the filler flap,not the cap . my 97 1.8 16v is 95 if that helps
x 1451
Unread post by xantia_v6 »
The engine has a knock sensor, so will adjust the timing to suit either grade of fuel. It should be a few percentage points more efficient on higher octane, but as they say, your mileage may vary...
Harry1975
how do you adjust a knock senor ?
x 8365
Harry1975 wrote:how do you adjust a knock senor ?
You can't, it does it automatically. It actually listens for the sounds of the engine knocking and retards the ignition timing until it stops. All fully automatically. Hence why it can compensate for different fuels.
The knock sensor is just a microphone attached to the engine block. As simple as that!
MortyDK
I had an older Xantia before -- a 95 with a 1.8 engine. When I accelerated briskly, the engine would sometimes pull un-evenly, i.e. the engine would audibly stutter a bit, and the car wouldn't accelerate smoothly. This only came when I pushed it a fair bit, and usually in warmer weather.
Is that related to the octane being a bit too low for the engine, or is it something else?
Thank you,
Harry1975
thanks for info on knock senor , i thought that was the case, i know for sure now cheers :)
MortyDK
This is a great forum! Thanks for the answers. :-)
