C5 Alloy Wheel Key/Adapter
wigelywoo
Unread post by wigelywoo »
Does anyone know where I can get an alloy wheel adapter from.
Just had a tidy out and it's not where it should be.
There are two secrets to success
1. never reveal all you know
Matrix MG
Re: C5 Alloy Wheel Key/Adapter
Unread post by Matrix MG »
what type of locking nut is it?
if it's McGuard you need the documentation that came with it originally to order another one.
if you contact McGuard i think they are able to identify the pattern needed from a photograph too.
wigelywoo
The bolt has 3 holes in it and the adapter has 3 pins.
Lighty
x 35
Unread post by Lighty »
That is not a Citroen key, I reckon you will need to extract them in the brute force mode :(
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Matrix MG
how big are the pin holes?
the only bit of sideways thinking i have at the moment is to use some steel bar of the right diameter to put into the holes and then use a ring spanner as a lever to turn the nut, basically put the ring over one of the rods and turn with the other rod against the neck of the spanner.
C5Alan
Unread post by C5Alan »
you could try some of the tyre garages I have heard from others experience that may have the right tools to remove locking nuts if you dont have the key ,ight be worth getting them all taken out and replaced with new ones with a key sooner rather than latter incase of a puncture
2003 C5 2.0 HDi 110hp Exclusive only done 218,000miles so just about run in. Family owned from new. Now Sold
2002 Renault Scenic 1.9Dci 111,000miles the new work bus
