citroen c5 passenger side wheel bearing
dudarus1
got a problem with my c5 bought the car and the passenger side wheel had some play when i got it checked the service and that bearing had been changed not so long ago. anyway got the bearing done at a garage and its still the same could i have a worn hub ?
Mobile Towbar Fitting Service In The Midlands
http://www.jninstallations.co.uk" onclick="window.open(this.href);return false;
Cheapest Prices Guaranteed
- x 1240
Re: Citroën c5 passenger side wheel bearing
Is it a taper roller bearing? If it is you should be able to adjust it.
dudarus1
not sure all i know is the bearing had to be pressed into the hub how can i adjust it ? thanks for your help
- x 94
if its a front bearing we are talking here its not adjustable,
what pulls it up tight is the hub nut and the CV joint, they have to be F/T tight,
try firstly tightening up the hub nut some more
Regards, malcolm.
