Hi guys, perhaps somebody has had this fault before and can help me, the engine management light comes on after start up when hot, after the engine has been turned off for ten minutes or so, i used a lexia3 to analyse it, and it says under intermittent faults:-
" Control of the turbo piloting valve short circuit to -ve or open circuit" i dont know if theres a part two to the lexia which explains what that means, or anybody knows the answer, many thanks in anticipation.
- x 1056
Re: engine management light
Firstly you should add what citroen model you are talking about & what engine is fitted to it & it will be eaisier for people to help you.
