c3 automatic diesel gear change help
robti
New User
Unread post by robti »
Hi parents have just got the above and when changing gear you get a long pause so the car slows down for a couple of seconds then catches up, you can also feel this.
So just wondering if this is normal for this type of box
x 1056
Re: c3 automatic diesel gear change help
Unread post by wheeler »
If its a sensodrive gearbox with the paddle shifters at the steering wheel then this is fairly normal, its not a proper autobox, its just a normal manual gearbox where the gearchange & clutch operaton are done by motors.
If its a regular auto then it's not normal for there to be a delay when changing.
robti
New User
Thanks for your help, yes it is the one with the paddles, they just got it on mobility and just wondered if it was correct, they have learned to get used to it now
Robert
