Hydractive fluid level check C5 2002 HDI 110
iwoo55
Unread post by iwoo55 »
How do you do a Hydractive fluid level check ? the owners manual does not tell you how to do it?
Also what colour fluid should I have in the system, its currently green.
I am asking the question as went to change my drop link last night and the suspension went to high but the pump still kept when the engine was switched off (was parked at an angle on my sloping drive) also noticed a slight fluid leak from the NSR sphere so might be losing fluid slowly.
2002 C5 2.0 110 HDI Manual Estate with 135,000 on the clock
SaabC5
Re: Hydractive fluid level check C5 2002 HDI 110
Unread post by SaabC5 »
If you have a C5 then you should have the bright orange LDS fluid in the system, not the green LHM fluid used in Xantia's etc.
iwoo55
Thanks SaabC5 (had a 9000cse for 10 years myself) done a bit of searching with the info you gave me and it may be ok
http://www.frenchcarforum.co.uk/forum/v ... =3&t=31293 in fact it may be green LDS in my system (how do you tell)
SaabC5
Hmmm, very good question. I'd be inclined to get it drained unless i could definitely prove it was the green Comma LDS, i've never seen it on sale only the bright orange Total LDS fluid.
