Buying info for a mk2 c5 1.6 HDI
imperial21
Unread post by imperial21 »
Hi All
I am ging to look at 2005 C5, it 1.6 16v HDI , Do you know any thing i should look out for in particular with these engines ? The car has done a few miles at 170k do they do the miles as well as the earlier cars do they have a particule filter? Do these C5 s have the hydraulic suspension ?
Any info gratefuly accepted.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Lighty
x 34
Re: Buying info for a mk2 c5 1.6 HDI
Unread post by Lighty »
Blimey that's some miles for a1.6, I have a C3 withthatbengine hat has done 270K miles, and is still good, and on its original turbo.
If it has reached this mileage it might be fine, you need to check type of use, Ie long journeys (these are best), how often oil changes were done, how many turbos it's had, that's a good test of how it's been looked after.
The car will have a dpf, the clutch and dual mass flywheel maybe suspect.
The car does have hydraulic suspension, but it is powered by an electic pump, and nothing like cars you will have had before.
The suspension by rights is quite reliable.
If the car has dual zone climate, make sure you can adjust the temp on each side individually, as the flaps inside the heater box break quite regularly.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
