timing belt change on a berling mk1
john
Unread post by john »
anyone done it on their 1.8 petrol?
usual questions, how long did it take? straight forward or a PITA?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
x 8423
Re: timing belt change on a berling mk1
john wrote: usual questions, how long did it take? straight forward or a PITA?
Precisely what engine John? The type of engine determines very much if the job is a PITA or not!!!
john
XU7JB
Subaru Impreza WRX
Nissan Primastar
x 8423
If that's an 8 valve engine then it's an absolute doddle.
You strictly need a SEEM gauge to set the tension but if you have a good feel for the 90 degree twist you can get away with it...
Just beware the index hole in the crank pulley may not be accurate if it's on the outside half of the dual mass annulus...
Apart from that. No issues...
john
yeah standard 1.8 8v petrol
ive got a haynes but typically it doesn't cover my 1.8 engine :(
Subaru Impreza WRX
Nissan Primastar
spider
x 77
Unread post by spider »
8v units easy, just pin in cam and the crank pulley.
Only real "problem" as Jim has said (more common on the 16v units I think) the pulley outer can move slightly so its not right. How to tell: Turn it and get the crank pulley pin in, then look at the cam one, obviously if its 180 out turn it and try again but if it appear to be 3 or 4 teeth out your crank pulley is unwell. This does not appear to effect the engine only a problem with these when its timing belt time.
The only other problem (not applicable in your case) is the very early I think pre 88 ish engines ? eccentric tensioner arrangement they curiously had.
That 8v unit was fitted in 306's, 405's and I expect some early Xantia's / ZX's too may be worth checking and obtaining a manual for one of these vehicles if you're in doubt although double check first it does cover your engine as later units are 16v.
Andy.
x 8423
Other BoLs that will help are the BX, XM and 205. The BX16 and 19 used the 8V engine along with the 2.0TCT in the XM and of course the Xantia Activa although the Xantia BoL is a bit silent on this engine and mixes 8V cambelt replacement up with the 16V... The 205 Auto, 1.6 and 1.9 205GTi used essentially the same engine but with the different (but very effective) tensioner you speak of Andy. I'd expect the Berlingo to have the later tensioner which is precisely like the one used on the TU and 2.0 HDi diesel engine.
spider
x 77
Can't believe I overlooked the 205 :oops: :oops: :oops:
Andy.
