c5 front wheel smoking
Robert12
Unread post by Robert12 »
Hi c5 hdi 2.2 exclusive 2002,just bin out in it and the front passerger wheel is red hot disc and pads seem ok,any thoughts any one thanks Rob
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You could try patches?
More seriously, is the handbrake actuation lever on the caliper, free? With the handbrake off, you should be able to move the actuator with your fingers readily (not far) and have it return under mild spring pressure to a consistent position.
C5s seem to get corrosion inside the handbrake cable guide tubes (even in Australia!) that will affect cable return when the handbrake is released.
Robert12
Re: c5 front wheel smoking
Thanks for quick reply, just took wheel of again and the little lever seems to stick with the cable off it
waynedance
x 8
Unread post by waynedance »
Had this problem a few months back and did get the lever moving but last week brake started sticking again so had a new calliper in the end for £53+vat trade.
Volvo S80 D5.........
Robert12
ok will try motor factors tomorrow see if they can match that price,
waynedance
x 8
Got that price as I work at a garage. good luck fixing.
addo
x 95
You would do well to check the cables for sticking with both caliper ends unhooked.
Robert12
the cables seem ok its the lever on the caliper sticking
x 5674
Chris (citroenmad) has a post here somewhere where he was able to recover operations on a caliper with similar symptoms to yours but eventually had to replace it.
I had to replace a calliper on my previous C5 for the same reasons last winter.
Robert12
new caliper fitted, on checking brake fluid noticed a broken plastic rod next to the head?
Citroenmad
x 110
Unread post by Citroenmad »
myglaren wrote:Chris (citroenmad) has a post here somewhere where he was able to recover operations on a caliper with similar symptoms to yours but eventually had to replace it.
Yes, once they get corrosion inside they seem to be unrecoverable. They can last a while but usually the problem of the sticking handbrake lever returns.
DO you have a picture of the broken plastic rod?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Robert12
it keeps saying image invalid when I try to upload
x 5674
Robert12 wrote:it keeps saying image invalid when I try to upload
What's the image and where are you trying to put it?
Email it to me - button under my username, and I'll bung it in for you.
Robert12
Have emailed some pics to citroenmad thanks anyway
x 5674
OK, no problem.
