Xantia rear bump stops
Taffyrhys
Unread post by Taffyrhys »
I was checking the rear brake pads yesterday when i noticed the rear rubber bump stops are perished, can anyone tell me where i can get some replacements at reasonable price. :-D
Cheers
Taff
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Do you mean the phallic ones, or the little pyramidal items?
Both are dealer only parts; not common on Fleabay.
Xaccers
x 188
Re: Xantia rear bump stops
Unread post by Xaccers »
They're abou £16-18 each from the dealer
DIY sphere tool
x 8391
And very easy to replace.
I did a piece on it in a recent Citroenian....
Stekelly
Unread post by Stekelly »
I noticed mine were in fairly bad order a while back, wouldnt mind changing them too. Every time I think of it I have a look on ebay but theres never any. Looks like I'm off to the dealer so.
Taffyrhys
I have a Citroen Xantia "Y" reg estate 110 hdi, i don't know what shape the bump stops are, as there's only the bit left where it fits into the chassis member!, can you buy a universal replacement part. Or is a trip to the scrapyard.
Does it make a difference if i don't replace them, as i suspect they perished years ago?????????????
Cheer
Taff
It still raining in Hertfordshire, where is the summer?
x 8391
This is what they should look like Taff...
I guess yours look like this:
Addo says they look phallic. If so then Aussies must be very different in that department :lol: :lol: :lol:
addo
x 95
OK, so it looks like a wichetty grub, then. :lol:
x 8391
Re:
addo wrote:OK, so it looks like a wichetty grub, then. :lol:
Yea, that's better, a big, fat well-fed one...
Maybe we could use them as substitute bump-stops :roll:
x 5674
I think Adam should exclude them from his diet before it is too late. :twisted:
Taffyrhys
Thanks for the photo at least i know what they look like. How do you fit them ? do they bolt onto the chassis?
Cheers
Xaccers
x 188
They just screw/press in
DIY sphere tool
Xantia AW
Unread post by Xantia AW »
"I was checking the rear brake pads yesterday when i noticed the rear rubber bump stops are perished, can anyone tell me where i can get some replacements at reasonable price."
I'm a bit out of touch with Citroen mechanicals but have you tried GSF car parts?
http://www.gsfcarparts.com
x 8391
Xantia AW wrote: I'm a bit out of touch with Citroën mechanicals but have you tried GSF car parts?
Dealer only so far as I know...
