Simple question
andmcit
x 30
Re: Simple question
Unread post by andmcit »
There's a pair of windows that need to unclip and hinge out of the way if the bolts
by using a fine blade screwdriver.
Nothing moves you like a Citroën
x 8427
Re: Simple question
andmcit wrote:There's a pair of windows that need to unclip and hinge out of the way if the bolts
What Andrew means by windows is little plastic flaps that conceal the screws.
x 8427
Re: Simple question
Mike, You need to remove all grab handles, the trim around the inside of the sunroof, it's U shaped and delicate, and then pull down all door rubbers and finally ease it down from inside the tailgate. It's bonded here with two large pads of black glue.
Check the drain pipes are securely fitted to the internal sunroof gutters. The rubber pipes join to clear plastic 'collectors' which then attach to the gutters. Often these collectors detach from the gutters. Refit them by bedding them back in using bedding mastic and secure them with a cable tie.
I have a picture somewhere which I'll post when I find it that illustrates this nicely.
Another source of leaks are the roofrack mounting holes under the door gutters. They are blanked by plastic stickers which deteriorate over the years and allows water in. Fill them with silicone sealant if necessary...
x 8427
Re: Simple question
Mike, here's the picture..
You only need to drop the rear part of the headlining to gain access...
andmcit
x 30
Re: Simple question
The sun (pah if only) maybe's bright light visors and the clip securing them
also need removal. The headlining will need a fairly hefty tug as it's held up
onto the roof with strong Velcro: it feels wrong twisting it and it creases up
as it's being pulled off but it springs back into shape again without any damage
and none the worse for wear.
x 1473
Re: Simple question
Unread post by xantia_v6 »
If you gently pull on the wire attached to the sunvisor, a connector should appear from the space above
