Peugeot 306 Petrol To Diesel
Is It Possible For Me To Put A 1.4 HDI Engine Into A 1.4 Petrol 306? If So How Would Would I Go About Doing It? And What Would I Have To Change?
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 24
Re: Peugeot 306 Petrol To Diesel
YES in the same way that you can fit pretty much any engine in any car....
long answeer:
are you nuts?
the 306 never came with a 1.4 HDi , and in fact only came with any HDi engine - a 2 litre toward the end of its `life` , for the most time it had the awesome 1.9TD and not quite so awesome 1.9 non turbo; so you would need the engine , wiring loom (all of it) , gearbox , weld in some engine mounts ,and the ability to set everything up including the computer you`ve just got which you dont have , oh and change the fuel system - complete , from petrol to diesel (and prolly missed alot)
sell the 1.4 and buy a TD
long answeer:
are you nuts?
Simon
i agree with most of what Harlequin says
apart from the welding in engine mounts, as i thought all the PSA lumps that hang from mountings like the XU/D's and TU/D's, and pretty sure the HDI's will switch from any model cit or pug,
Regards, malcolm.
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
It will fit as far as I know it uses more or less the TU engine mountings. You'll need the diesel gearbox.
Regarding electrics, its mostly plexed. You'd have to source / customise a 107 HDi / C1 HDi loom into the 306 one, unless you wanted to go plexed, which will be very difficult with a 306, possibly using a 307 and a 206 as donors.
It's likely to be very difficult to do, especially dropping it in will not be that bad just mixing / matching mountings / pipework / exhausts, its the electrics that are going to cause you problems. You'd also need to replace the pickup in the tank with the diesel unit too.
TBH, the TUD5 is a better choice in a 306 (yes I know it was never fitted into this) as it will drop in more or less and be very reliable. Failing that an XUD over a DW8
Andy.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
One of these would probably be a lot cheaper:
http://www.ebay.co.uk/sch/i.html?_trksi ... i&_sacat=0" onclick="window.open(this.href);return false;
It's not worth doing far to much aggro, you would be better off just buying a diesel version.
- spider
- x 77
- Contact:
Agree. Unless there's something really specific about the current vehicle that makes it worthwhile to do that and not replace it.
Andy.
Yes Harlequinn I Know That It Never Came With This Engine. And The 2 Litre Or 1.9 Has To High Tax. 1.4 Hdi Would Be Far More Economical And Cheap On Tax. Spider I Was Also Thinking About That 1.5 Engine Aswell. Would That Be An Easier Job?
You won't get much more economical that the 2.0 Hdi, I can easily get over 60mpg from my 406 which is a lot heavier and the tax is £130.00 per year, it would probably be less in the 306, providing you car was registered after March 01, otherwise they are all the same.
- Xaccers
- x 184
I'm sure someone posted elsewhere that even with a different engine your tax will not change.floggmolly wrote:Yes Harlequinn I Know That It Never Came With This Engine. And The 2 Litre Or 1.9 Has To High Tax. 1.4 Hdi Would Be Far More Economical And Cheap On Tax. Spider I Was Also Thinking About That 1.5 Engine Aswell. Would That Be An Easier Job?
DIY sphere tool
DIY sphere tool
For the engine size/emmisions to make any difference to the tax class that car must be registered after Mar 1st 2001.
- spider
- x 77
- Contact:
It was me who posted in Chat about theoretical tax questions.
The TUD would be far easier to fit though if you really wanted to do this but I don't think your tax band would change anyway as Peter has pointed out.
Not to mention your insurance company will not be happy (read expensive) if you do a conversion to something that was not factory produced.
Andy.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4924
Indeed, mine had a fit at the time and I had to supply an engineers report to them when the 3L PSV engine was removed from my Volvo 265 and replaced with a lowly 2.2L 4-banger.spider wrote:It was me who posted in Chat about theoretical tax questions.
Insurance doubled
